TractorLinks.com
Re: 310d back hoe
ben brown
12-08-2013 17:01:55
no its a d series has forward reverser with toque converter with drive line i took it a part it slip in 3 4 gear though it might be the clutch pack but all look good replace all the sealing rings and piston rings on reverse brake and froward clutch pack but still dont have enough pressure. on front clutch so took it back out tore it down again nothing really stick out but does have a lot of by pass air on forward clutch.
Roy Suomi
12-09-2013 10:40:54
 Re: 310d back hoe in reply to ben brown, 12-08-2013 17:01:55
I have accidently cut a small section of the rubber piston sealing ring on other machines.. Easy to do..Is there something missing ?? Maybe a thrust washer ? Any steel or rubber rings should seal.. How about a surface where a ring seals ??
