TractorLinks.com
Re: Allis Fork Lift No Start
AJ.
12-06-2013 20:02:16
What model Citroen engine is it,you say the timing is ok and that it's got a spark,what about gas,did you clean the carb,see that all the intake manifold is tight and the gaskets are good,if the manifold is drawing air it will not draw the gas,if thats ok remove the spark plugs,put a couple of cc's of gas in each cylinder and put the plugs back in pronto and try and start it,no ether,if it catches you will know its a gas/carb issue,a lot of Citroen engines have cambelts,they can strip the teeth but you would have checked that,do like Mike said above see the valves are working.
AJ
