AC HD10 final drive problem
lemroy
I think I have a bearing out on my HD 10 final drive. What is the best method of replacing it. Any input will be greatly appreciated. Roy
First dozer I ever owned 60 + years ago was a Detroit powered HD10 AC.. Seems to me the final housing does not come off. You have a plate with bolts that access the end of the pinion bearing, then a large cover on the bottom to get to the lower shaft. Lots of work what ever you have to do. I think I have the original service manual here somewhere if you get hung up.
Thanks for your input. I have a service manual however I may need some help. Where can I get the bearings? Roy
Not meteric and I am thinking an good bearing house can match them up IF you have anything left to get numbers from
Thanks for your reply. I was able to find bearings for the other final drive. However some of the bearings ar e no longer made. When I get it torn down, I will try to locate some. Roy
