TractorLinks.com
Re: Case 1840 - Installing Hydraulic Motor
AJ.
11-13-2013 19:35:27
I meant the hoses that are attached to the motor you changed,not every hose on the power train,the way I would have removed that motor was release the pressure from the reservoir by loosening the cap,mark the hoses,undo them and cap the ends then remove the motor,to replace the motor,fill it with clean oil,put it on and connect the hoses,top up the oil the job done,as the machine was driving ok before the motor was taken off it is fair to assume that the motor or the fitting of it has an issue,
AJ
