Case 310g Governor Springs
bkm1954
New User
Can someone explain and/or provide a picture of the location and attachment points for the throttle and governor springs on a 1969 310g (gas).
I "inherited" the dozer from my father-in-law and someone, at some point, bypassed the governor completely in an attempt to fix the idle.
If I remember correctly, the governor spring consisted of an inner and outer spring. They appear to to still be behind the generator but are not attached to anything. There was also a throttle return spring (I think) for the foot pedal and dash lever.
Any help would be appreciated.
Thanks AJ... but, unless I'm doing something wrong on the site, there seems to be nothing for the 310g on the site.
Still looking for help.
Go to the link,first page opens,top left click Find parts by model,another page opens.type in 310G in the search box,hit search,four options appear in the left panel,click on your tractor.another page opens,in the left panel there are two icons,click on No Description,the right will show several sections,find the one with governor spring,you are there.
AJ
http://partstore.casece.com/us/
Thanks AJ! I'm not sure what I was doing wrong but, following your instructions worked perfectly.
