Anonymous-0
Iam working on this machine 12,500 hrs I had the hyd pump rebuilt because it was worn installed the pump and run pressures and I cant get more than 3000 psi on any single pump function bucket, swing and travel when worked one at a time so I know its not in the pump because the negtive control line works fine and when I use both tracks pressure is ok I have checked circuit reliefs they are fine so somewhere in the main control valve it is bypassing you can hear it and it only has one main relief that works also any one ever run into this And I have gone into the monitor and changed the modes so that is not it either
