Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Stanadyne ijection pump failure.
2x4
10-24-2013 20:17:33
Prolly not going to be able to find someone to work on it so will buy a new pump. The work around of the broken ear was done by the last owner. Since it broke thru the eye, they enlarged the partial hole somewhat & ground down a nut to act as a washer, which filled the space nicely, then bolted that ear. With the other 2 bolts holding, it was solidly mounted. But it means someone had the pump off before me, so they could have already been having some problem. It may or may not be the original pump. There was a small amount of water in the glassbox filter but in numerous bleedings, only pure diesel came out the bleed nut at the top of the filter. Had put a new transfer fuel pump on & hand pumped it up & bled it. At the bottom of the fuel tank, the water bleed screw only let out a teaspoon-full. Haven't talked to the repairman yet about the cause.
