I have an OLD Cletrac crawler. Where can I get some info to help to determine year and model? It has the steering wheel instead of friction levers. I'm going to guess it's a start on gas , run on fuel as it has 2 fuel tanks. I'll also guess it weighs in the 3-4000 pound range. Any help is appreciated.
John
http://cletrac.org/forum2010/
Right now, at 7:15AM 10/25/13, it's down for work, but should be back up soon.
Sounds like a Cletrac model W. First crawler to ever get a Nebraska Test in 1920. 15.5 drawbar horsepower and weighed 3300 lbs. Used a 226 cubic inch, four cylinder Wiedely all-fuel engine.
Where do I look for ID plate?Here is a Pic of it.
if you have a model w it should be 1 speed forward an backwards,3speed would be a k-20 with cleveland engine. the earlier model h had whedly engine.i have a 1928 modle w,with cleveland,my dad used it when he was a teenager,an now he is 85.ihave had a lot fun with this small crawler an lot of interesting comments.what you have is not a totaly rare but is not a common tractor at most shows. e-mail is open if you want to contact me. dan
The tractor doesn't run and I'm not sure about the gear box. I'm also not to familiar with the workings of this forum. I'd like to send you a couple pix but I don't seem to be able to figure out the pix posting or figure out your e address.
John
