How do you work the bucket?
Look at this dozer or loader or backhoe! I dont see how you can use the loader without digging with the dozer blade in the ground.
PecosAllis
Simple, you remove the blade, to use the bucket.
The blade needs the bucket to lift it.
In short someone added the blade to a crawler loader.
The only down fall is it won't push quite as good as a dozer, "unless" the track grousers have been changed; then it is a real pain as a loader (when on hard surfaces).
HTH
Brian
If I remember right Deere sold blades like this as an option and like others said it was taken off when not grading.
