TractorLinks.com
Re: Stanadyne ijection pump failure.
Dieseltech
10-24-2013 04:06:07
Sounds like retainer flex ring failed and with continued use the retiner pins sheared off, which then locks head/rotor assembly, and shaft breaks. Will be seen on teardown inspection if that's what happened.
jdemaris
10-24-2013 04:55:16
 Re: Stanadyne ijection pump failure. in reply to Dieseltech, 10-24-2013 04:06:07
There is no "flex ring" in that pump. 550G uses a DB2 or a DB4 pump that uses an EID drive instead of the plastic ring like the JDB pumps had.
The story sounds to me of one of bad fuel with low lube.
