Bobcat 331E hydraulic problem
Anonymous-0
The boom, right travel work circuit works fine, but the left travel, clam blade and other functions do not.I can only build pilot pressure on the weak side unless I bump up on the boom lever. my main relief pressures are good and pilot pressures are good. it recently had a pump failure and the pump was rebuild. Any Ideas would a great help
I had a tiny (1/8") piece of metal plug somewhere in the hydraulics. Thankfully the Bobcat mechanic found it.
