grizz123?
New User
I was driving along when I started to slow down then stopped. No oil on the ground, but the clutch pressure dropped. Any ideas what"s wrong?
Can't find suction filter. Pulled top cover plate can't find filter,but did find dip stick, looked no oil. Looked under and saw a drop of oil. Is there a seal?
Well yes there is a u joint and yoke there on the back of the torque that has a seal. Hope you have not damaged the unit by running it without oil. Do you have a book? Do you know what kind of oil to add? Did you find two dip sticks or just one?
Yes I have a manual. Looked in manual but suction filter was not where it showed. I only found one dip stick.Doer only leeks when I turn. Any ideas?
