case 350 dozer
Anonymous-0
have 350D case dozer s#3054941 after running about 1-2 hours loses power going forward reverse is fine any ideas on where to start checking for fix clutch pressure stays same according to gauge on dash thanks in advance for all help
That sounds like the forward clutch pack is slipping,could be due to the clutch discs worn,the Belleville spring cracked or not enough fluid pressure to squeeze the discs together,when you got a good reverse that means that the torque,the charge pump and reverse clutch is OK,about the only thing you can do with that shuttle in situ is check the F/R linkage and the pressure.
Good luck
AJ
