serial number
cdeleo
New User
I'm trying to find a serial number on a td8e. the plate that is down by your feet on the driver seat is gone. Anyone know where else a serial number would be?
Serial number on the engine may help also
Dresser TD8E
Going to be hard to explain but it is stamped IN THE REAR housing now here is where. If you walked up to the rear of the tractor and just tried to reach around the rear end your right fingers should be on the number. Written vertical on the rear of the right side right behind the final drive housing. Please post back if you find it or not.
jm,
Thanks this is the number that I found. Wasn't what I thought I was going to find. Was expecting a number like 442xxxxU. unless it is just the xxxx part so 4425095U? Not sure if the 8 in the picture is part of the number or not?
Thanks,
Chris
Sorry forgot to go back and check but yes you are exractly right only the last 4 digits are the actual number the rest is the series and it would have been found on that plat at your left heal.
You have it figured out now. LOts of folks do not ever find that stamped number. Glad to be of help. Probably have owned 20 or more of those td8s over the years.
