Case 580CK front wheels
RMberme
New User
The front wheels of my Case 580CK are cracking
about an inch from the mounting studs.
Can these wheels be replaced by regular implement wheels; or, are they heavier metal for industrial application?
the six bolt hubs that came on 580CK's are just a std wheel I run aftermarket ones on mine never had one crack, the 580B's had the option of the 8 bolt hubs and they are at least twice as heavy
There is also an aftermarket reinforcing ring that can be tack-welded onto the bolt area of the rim. A lot of cattlemen around here use them on their loader tractors.
The cracks don't go out from the stud. They are in a circle, about an inch out from the studs.
If the wheel were to break off, the very center with the studs would still be on the hub.
