TractorLinks.com
Re: Case 310 Track connecting tool
NCWayne
10-10-2013 15:16:27
If your putting together two links with a master pin you need to move the track so the two links are on the drive sprocket. With the links on the sprocket slowly move the machine in reverse enought to pull the slack out of the top side of the chain and put the joint at somewhere around the 10 o'clock position. With that slack out of the top side, put a jack under a pad on the lower part of the track and pick it up into the upper link. If done right there won't be any tension on either link so the pin should drive right in without any major problems.
jm.
10-10-2013 18:00:12
 Re: Case 310 Track connecting tool in reply to NCWayne, 10-10-2013 15:16:27
Boy you saved me.. I was not going to ask, I did not even understand the question. I thought I had been missing something all these years. Cross tie block layed down right at the joint of track pad 2/3 then back up till ever thing gets tight flop it over and if a tractor, or come along at the most pull it to 10 o clock like old said and drive that pin in. Tonight sitting here I can actually say sure do wish I had a 100 dollar bill for ever one I have drove in. We used to have a 20 pound sledge on the service truck. If you missed there went the handle but sure would move that pin. Latter years I leaned take it to a grinder and really clean it, leave it in the freezer over night and job was easy. Thos little washers was another thing. O he never asked where they go.
