rfh129
New User
So I have a 1700b JCB hoe that shut off and wouldnt start. I can jump the starter selonoid and turn the key it starts, but it won't go forward or reverse. It has hydraulics and the fluid is warm on the stick. Does anyone have a wiring diagram? I have continuity through the pedal switch.
Thanks
I don't have a manual for the 1700B but do for the 1400B,go to the link below and you can download a copy,it is a very similar machine,this manual covers the electric shuttle shift with a four speed stick shift gearbox,the common cause of the problem you are having is the F/R shift switch,that switch controls the F/R and neutral start,the contacts inside can wear out,the switch is not cheap so you need to establish if its failed before buying a new one,follow the trouble shooting guide,the electrics start on page 461,on the top menu of the first page you will see a square box with the number 1 in it,delete it and type in 461 and hit enter,that will take you to the electrics,scroll down and you will find the start section.
Good luck
AJ
http://www.fileswap.com/dl/TCEDJHWiyA/JCB_1400B.pdf.html
had an email saying that link don't work,it does for me but i do subscribe, try the link below instead.
http://snk.to/f-c7na68fn
