Anyone know of a good source for a used 723 control valve? Turns out that the major hydraulic leak I thought was a blown hose is actually a couple a cracks in the valve body. One I think I can weld but the other is on the top and intersects 2 of the spool bores so I don't think welding is practical.
Do any of the later hoes use the same or a similar valve setup? I can modify mounts and make the hoses work as long as it's close, what I'm more concerned with it making sure the hydraulic side is correct.
Thoughts?
Thoughts?
