TractorLinks.com
Re: Bobcat 753, with Hydro Pump Problem
jm.
09-30-2013 14:27:48
Not anything to worry about in the hydraulics but there is ONE big issue, which engine does it have. I bought a bobcat at auction about like your project. Assumed it had the KUBOTA as most do. Turns out it had a perkins. Had to go overseas to get engine parts turns out BobCat no longer supports this engine but it gets worse some have an another engine like an issu or something and parts are not there for that engine also , so check the engine and see what is in you machine.
thynes
09-30-2013 15:26:24
 Re: Bobcat 753, with Hydro Pump Problem in reply to jm., 09-30-2013 14:27:48
JM,
The Bobcat has the 4 cylinder Kubota engine.
From the looks of it I don't think it has ever been overhauled. With 5000+ hours, what kind of service, or problems could I expect from this?
Tim
jm.
09-30-2013 16:45:09
 Re: Bobcat 753, with Hydro Pump Problem in reply to thynes, 09-30-2013 15:26:24
I don,t know. Been a KUBOTA dealer for 28 years and probably have seen more engine failures in bobcats than all other things combined. Bobcat chose to mount the radiator up high on some units and not unusual to see overheating issues in the bobcats. At 5000 hrs I would say you are certainly on the edge of use full engine life if it has not already been overhauled. The 753 is a real popular unit but you can also pick up used ones when they get older fairly cheap.
