Greetings one and all! I usually hang out on the Fergy board and I now need to get one of my (2) Cat 22's in running order.
The first one showed up about 7 years ago, open stack and froze engine. I pulled the plugs, dumped in many concoctions and it is still sitting. Too many other projects. The neighbor down the street moved to heaven and I got his Cat 22 less the Eismann mag and air cleaner. The first cat has the missing parts to make it run. The motor turns over easy enough.
I am searching for a service manual that can be used on the cat 22. I know they weren't made. So which (Model 20?) manual can I use and where can I pick it up? I know this site sells them.
Which one? Got another better source? I anticipate both a 20 and 25 manual might be needed to get me Ed-U-Kated on this machine.
Thanks in advance!
Thanks in advance!
