After setting the winter, engine started sucking water into one cylinder and oil. Also, was spewing water out around the two bolts on the "air chamber" cover on the right side of the engine. Thinking antifreeze may have been low, pulled the engine apart and found nothing that jumped out at us. Didn"t see normal signs of head gasket leaks; but, only ran engine 30 minutes or so before seeing the problem and shutting it down. Know nothing about these engines; would a leaking head gasket allow water into the air chamber or do we need to look further? Have a new overhaul kit; but of course, don"t want to install it until we"re confortable as to where the water is coming from in the airchamber. Any help or suggestions is greatly appreciated.
Thanks,
Carl
Thanks,
Carl
