TD6 pull left unload or unhill
Guys my td-6 was working great for about 24 hours of uses. But it has problems. The left side track stuck and it just turned left do to just the right side track only turning. After pulling the dozer back to the truck with a tractor the left track started turning. But would not turn the same as the right side uphills. Got the dozer home and found the carrier roller on the left side broken. I removed it to test if it would fix the problem but it did not. Just removed the brake pad on the right side and parts of it are metal to metal. Would this cause it to pull left uphill? What else can i check? Thanks for the help.
To me I am thinking you have a bearing going down in the left final drive or pinion area. Usually one of the balls will fall down and lock the bull gear or bust the housing. Pull the fill and drain plugs on the left final. See what comes out the drain plug, and sign of metal means tearing down the final.
