CASE 450 B Gauges
tommu
New User
What gauges were on a 450 B dash?
HELP
I am buying a basket case 450 that has set for 6 years.
The gauge on the left is missing. The engine oil pressure reads 50 PSI when first cranked. The other gauges do not function. I have a hoard of gauges that read from 0 to 300 PSi I can mount.
I really need one for Transmission pressure, Maybe others are critical.
It cranks up easily, but it dies due to trash plugging the fuel line under the fuel tank (I'll have to flush the tank and replace filters)
The transmission cooler in the radiator must have a leak because the tranny fluid and the water in the radiator are milky (I have flusher the hydraulic fluid in the transmission and run a bypass hose from to loop the supply and return tranny lines)
I only run it for 5 minutes due to the bad radiator.
The tracks are frozen. The machine only moves forward and back about 6 feet (I'll have to keep lubing the tracks with used transmission fluid and driving it back and forth gently and hope they free up)
Thank You
this is the dash of a 450 a "B" series I think is the same
cnt
I have a hydraulic blade for that dozer if you need one. $400 in West Virginia. The bare blade is the only part I have.
