MF400 bulldozer
Hi there. I have a mf400 dozer and need
pins and bushes on the chain track. They
are badly worn. Can someone help me with
contact nr or email address of a parts
company that can help me. No one in south
africa can help me and I need the dozer to
work.
If your pins and bushings are that worn, the rails are most likely worn out as well. You probably need new sprockets too. New pins and bushings on an old sprocket will wear them out pretty fast. Are the pin bosses flat from hitting the bottom roller flanges?
Some of them are touching the pin boss. So that means the chain needs replacement as a unit? I have a 1/4 rear half of a mf400 dozer with a good sprocket that I can use. But unfortunately it doesn't have any tracks on it.
Berco make undercarriage for the MF machines.There will be a dealer in Sth Africa.They should have drawings on file for your chains,Idlers,etc. There will also be cheaper Asian import options if the D4 chain is usable.Check your lower rollers too.
