Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Dresser TD7-H Decel when turning right
JFoshee
09-07-2013 21:00:44
For anyone that is interested I found my problem. A cylinder inside the transmission pushes on a cam to actuate the brake and stop the track. The parking brake lever also actuates this same cam and is directly in front of the cylinder. My brakes were adjusted way to loose and when I pulled the handle for the right track it would actuate the brake lever, which is mechanically connected to the throttle so the machine would decelerate. Moral of story is...adjust the brakes before you pull the hyd tank and the left side like I did. Brake adjustment is external at about 2 o clock position behind the sprocket. 1 1/2" wrench size for lock nut and 3/4 for adjusting nut.
