AC HD5 Cylinder Liner/Sleeve Removal
Mokicker
Couldn't budge second liner typical hammer and block method; so, used first liner as pattern and cut plate to fit bottom of liner to serve as puller. Still couldn't budge it with breaker bar. Neighbor boy stuck a cheater pipe on it and the bottom of the liner broke. He did manage to pop it up about a quarter inch; but, it seems to be just as stuck as before.
Where do we go from here? Only idea we came up with was possible use air grinder and cut a slot down one side to take the pressure off.
Thanks,
Carl
One trick that is often used is to run a couple of weld beads from top to bottom. That shrinks the liner a little to loosen it.
Put pressure on liner with puller and fill liner with dry ice. Had a dry liner almost jump out of the block that would not budge.
