TractorLinks.com
Re: Dynahoe engine rpms really high
Brad Strouse
08-21-2013 08:35:02
Wayne,
First of all thanks for the quick response I really appreciate you taking time to help me out with this problem. I'm going to take off the valve cover this weekend and investigate what you have explained with the fuel injectors. Also I traced the stop switch line down to a device maybe the governor but not sure (also where the throttle appears to go to) and worked the levers back and forth no change. My question is shouldn't this device stop the flow of diesel to the injectors. Sorry if it's a dumb question I'm just trying to gain as much knowledge about what i'm getting myself into. Again thanks so much for your time and knowledge.
Brad
NCWayne
08-21-2013 13:51:30
 Re: Dynahoe engine rpms really high in reply to Brad Strouse, 08-21-2013 08:35:02
Not a problem. I was going to explain things a bit further to you, but check out the link below for a really good explination of Detroits mechanical fuel system. It tells you pretty much everything you could ever want to know about how it works along with pics so you can see it also. Hope it helps you when you go to look at it this weekend.
