DGK
need to pull big motor out to replace ring gear. How does that leaf spring in middle of tractor come out and can I put pony back on big engine and slide whole thing back together? Thanks for any help Doug
What I have done is run the rear of the tracks up on 12" blocks so the sprockets are sitting on the blocks. Remove the nuts on the 2 bolts that are holding the spring to the block and jack the front of the engine up off the spring. You can then remove the spring. The engine will be sitting level. Block under the bell housing and pull the engine. The pony can remain in place or not. Of course you need to remove the dash.
