Ignition Timing on a TD14A
Mark2
New User
Hi I have a TD14A that I just replaced stering clutches and other parts to get her back up and running. The dozer has been running in june , like a top, but I don"t have any spark now. I removed the distributor and cleaned the connection and I now have spark to the center post if the distributor but not to each plug.. so i checked the rotor and cleaned the connection but still no spark , well then I found out that my operator had removed the 2 screws from the under the distridutor cap and one of the gear fell out, well he put them back in but I do not have anyway of knowing if they are in the right position for engine timing. Any help ? Call me or write back I can give you more details then. Mark W 315 576 1974
Thanks in advance.
PS this is a Magneto system
