NH skid steer parts
Unless they are a propriatory design for NH, any Eaton distributor should be able to get the parts as long as you have the model number, etc off the pump. That being said, what part is leaking? I ask because of the shaft seal is leaking you are more than likely going to need a new pump. I say this because the biggest cause of the shaft seals leaking is a grove being worn into the shaft. Hope that's not your problem. Good luck.
I was ran with low oil, which got hot enough to ruin most all of the seals. I already did the drive motors. NCWayne, I do the same type of work as you, not too far away. I'm in Rowan Co.
I'm in Cabarrus County, not too far from the intersection of Hwy 601 and Hwy 24/27. Shoot me an email and I'll send you my number. Maybe we can meet up some time....Heck if you've been doing this as long as I have we've probably seen each other over the years anyway.
