JD 350 dozer
Completely different animal, a loader and a dozer. Different frame for one thing. You could put a blade on a loader boom but it wouldn't work the same as a standard dozer.
I have the complete frame & other dozer parts for the 6-way manual inside blade in central West Virginia. Frame, blade, blade adjust arms, tilt adjuster and one of the hydraulic cylinders for $400. 20 minutes from the Interstate.
I don't think an inside mount 6 way could be put on a loader. The main frame of the machine is entirely different as a loader has the uprights for the boom and lift cylinders. $400 is a good price but it only has 1 cylinder? If you could find a reasonable used cylinder would be a benefit. I just got a cylinder for a backhoe repaired and it was over $1000!
yes only one cylinder. Friend badly needed one for his 350 so I sold one to him. Was hoping JDE would jump in here & tell us what is what. Many years ago I saw a JD factory blade set-up for a loader. It was quite elaborate & replaced the bucket. Must be a few around somewhere.
