TractorLinks.com
Re: JD 440 IC Master Track Pin
Lavoy
08-14-2013 13:34:53
The pin is correct, buy you may not have a master link anymore. The master link that goes with the pin you ordered from Deere has a slot cut on one side for the head to go into, and the other side is milled off. If the link you are working on looks identical to all the other links in the rail, then you don't have a master link. Only way to do that is with a drive master pin. I have them in stock, let me know if I can help.
Lavoy
dcrouse
08-18-2013 18:54:14
 Re: JD 440 IC Master Track Pin in reply to Lavoy, 08-14-2013 13:34:53
Thanks Lavoy, I am glad you knew what I was dealing with. I have the slot cut on one side and will grind down the other side until I get enough metal removed to get the snap ring on.
