My problem is when you pull the right steering lever the machine will apply the parking brake which in turn will decelerate the machine because the brake/parking brake/decelerate pedel are one in the same on this machine. There are no issues when turning to the left, only when the right lever is pulled. Also, the machine does not need to be in forward or reverse it does the same thing in neutral. Looking for advice on what to check. There is not really any linkage because the handles work a hyd. valve then lines run into the trans. I am afarid I will have to open up the trans to repair this. Any help or guidance from someone who has worked on Dresser equip. would be appreciated. Finally, anyone have some leads on an inexpensive service manual. Found a digital copy on Tradebit for $10 but not sure about the site. Read some bad reviews on it.
