TractorLinks.com
Re: Is this bucket worth saving?
Stick welding
08-11-2013 22:05:24
Adapters are cheap and you want to be able to replace the teeth if need be. You could take the old adapters off with an angle grinder if you really wanted to. Welding new teeth on the old adapters is a real redneck repair. You might as well just use it as is if you're not going to fix it right.
Bob Bancroft
08-12-2013 03:23:17
 Re: Is this bucket worth saving? in reply to Stick welding, 08-11-2013 22:05:24
This just never ends. I wasn't advocating welding teeth on the shanks either.
Stick welding
08-12-2013 22:30:22
 Re: Is this bucket worth saving? in reply to Bob Bancroft, 08-12-2013 03:23:17
When you talk about fancy Eutectic rods maybe you could be more clear what you're welding. To weld shanks on you don't need any kind of special rods. 7018 is all you need. Now if you're welding the teeth onto the shanks or building the shanks up, then you might want special $$$$ rods. That size of shank on that bucket won't need preheat other than being at room temperature.
Tao On The Farm
08-12-2013 03:50:29
Bob Bancroft said: (quoted from post at 03:23:17 08/12/13) This just never ends. I wasn't advocating welding teeth on the shanks either.
I appreciate the input and thanks for clearing that up. Looks like:
1) Grind off old adapters
2) Weld on 4 new adapters
3) Hardfacing on the remaining edge
Last question (for now) is there a brand of teeth you reccommend or use or stay away from?
This post was edited by Tao On The Farm at 03:52:19 08/12/13.
Stick welding
08-12-2013 22:37:49
 Re: Is this bucket worth saving? in reply to Tao On The Farm, 08-12-2013 03:50:29
Just get the cheapest forged teeth like from Black Cat Blades or H&L. Probably 23 series H&L style with bottom mount adaptors and the rubber insert pins. Check the thickness of the lip and get the adaptor that fits. There are welded teeth available but they can break.
Bob Bancroft
08-12-2013 15:14:00
I just get them at the closest source. Which for me is my NH dealer. They are a farm equipment dealer but also have the backhoes. I got teeth for my old IH from them, and now have a Ford 655A.
