TractorLinks.com
Re: Is this bucket worth saving?
Stick welding
08-10-2013 17:57:38
Not a big deal to cut the old adapters off and weld new ones on. The adapters are only about $10 to $12 and the teeth about the same price. A good welder could fix that in a couple hours. Probably less than $300 for everything and you're good to go. That bucket is in good shape. It takes thousands of hours to scallop the lip but that's not bad at all.
If you get a welder, get one with DC current. It will make it much easier and a lot less frustrating. You can buy a DC inverter for less than a new tombstone and it's a superior machine. Wouldn't be a bad idea to weld some hardfacing on the bucket lip between the teeth to stop it from wearing any more.
Tao On The Farm
08-11-2013 06:35:27
 Re: Is this bucket worth saving? in reply to Stick welding, 08-10-2013 17:57:38
Could you cut out a "U" shaped piece and take out the adapters and scalloped edges in one fell swoop. Then weld in a new piece and put the new adaptors on that?
Stick welding
08-11-2013 09:52:28
 Re: Is this bucket worth saving? in reply to Tao On The Farm, 08-11-2013 06:35:27
You could replace the cutting edge as well but really, that cutting edge isn't in bad shape at all. The new teeth will be wider and help a lot. A couple beads of harfacing would stop anymore wear on the lip. New adapters and teeth and that bucket will out last you.
