hello! just picked up a case 310g first dozer
65310g
New User
Been flawless so far, running yesterday and it popped a couple times (track) then it lost all tension and came off bottom rollers. Picked it up pushed track back in place. Track is really loose now but tensioner doesnt look to have moved. Any thoughts?
Front idler guts shot? Final drive wiped out? If you need help with repair or parts give us a shout. Steve. www.sadygerts.com. (F/K/A Pdmechanical)
Not much there to see so any wear problem ought to be evident. Besides being loose - you' d better make sure the alignment is correct. If not, they will keep walking off.
My 310G was losing tracks quite a bit until I put new rollers on it (all the bottom rollers were junk). I also had to put in new adjusters. Mine has the mechanical adjusters which are available new and fairly cheap.
The new rollers from Korea were also surprisingly cheap. About $80 each delivered to my door on a pallet.
Also curious if anyone might know where I could get a throttle linkage, mine has been broken and welded eliminating the ability to use anything but the foot throttle
