Yesterday's Tractor Co.
Shop Now View Cart
Re: case 207 roosa master pump
07-31-2013 04:07:17
As Bob mentioned, return fuel flow is slight. With engine running loosten the timing cover so fuel can leak out to test for return side restriction, if it speeds up and runs better check all return line and fittings for blockage. If no change recheck supply side flow out of final filter, may have something slowing flow. Not common, but pump inlet screen may be plugged too.
mike jenezon
07-31-2013 09:04:51
 Re: case 207 roosa master pump in reply to Dieseltech, 07-31-2013 04:07:17
Pretty well eliminated return restriction ,took the return fitting out of the pump and ran it , no change , inlet screen in pump is clean and clear and ran elect pump to inlet bypassing filters ,so no restriction there . thanks mike
