TractorLinks.com
Re: case 450 dozer fan???
Jacob armour
07-31-2013 03:22:38
I took the fan off last night and tried flipping it but even flipped it still makes a pusher I figured someone put the blade on backward at first but apparently that's not the case the rad wasn't dirty at all from what I saw of it but ill clean it regardless and if it's still heating the old girls gonna get a high cfm electric fan
RodInNS
07-31-2013 06:13:13
 Re: case 450 dozer fan??? in reply to Jacob armour, 07-31-2013 03:22:38
You don't take the fan off. If it's a reversible type you push the blades towards the center hub and turn 1/4 turn until they pop back out. That way the leading edge of the fan is now pulling air from the rad side of the fan as opposed to the engine side of the fan.
If cleaning doesn't help then I'd open the rad cap... CAREFULLY and look in there for bubbles while it's running and check for circulation or other evidence of crap. It might be that the cooling system needs to be drained and thoroughly cleaned. I use a fast flush type of acid product available at NAPA and other such places...
The machine should cool itself fine if everything else is in proper working order. IT may be marginal... but it should cool.
How hot is it running anyhow? Is this a Cummins engine or the old big bore Case engine?
Rod
