TractorLinks.com
Re: Need Help 57 Cat D6 Cooling and Dumb Question
j hikemper
06-24-2013 21:54:13
toss a thermometer in it when you get it spittin water ,, guage could be wrong and radiator could be plugged , summer fan should push air forward , winter work reverse blades to share heat with engine and operator quickest best way I found to flush radiator fins is to idle motor way down and douse fan blades with simplegreen ,, then take a hose oand rev up motor and suck the soap thru the fins with water ,, worx quick and does a good job
NCWayne
06-25-2013 04:39:29
 Re: Need Help 57 Cat D6 Cooling and Dumb Question in reply to j hikemper, 06-24-2013 21:54:13
Unless it's equipped with a Huber, or other brand, of reversible fan it's going to push forward through the radiator summer and winter. Usually the main reason for reversing the direction during the winter, at least around here, had to do more with operator comfort (ie- heat for the operator on an open cab machine) than anything else.
