I just bought a 57 D6 9U that appears to be in very good condition except for a possible cooling issue. Temperature gage stays green, but after running long enough to get hot, it vents fluid from radiator cap. It never seems to get close to top of green on temp gage even if you continue to use it. When you add water next day it takes between half a gallon and a gallon to get to where you can see water in radiator. Am I over filling or do I have a problem.
Second question - fan blows lots of air volume out thru front - opposite of car which sucks air in thru radiator and past engine front to back - is this normal?
