Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Case 188 Roosamaster pump problem
Kelly MT
06-24-2013 08:43:14
I had a similar problem with my IH 350D pump. It turned out to be the small pistons in the rotor were stuck with a light rust. Moisture had caused just enough light surface rust in the very tight bore that they would not move. I dissembled the pump and polished the pistons and bore with note pad paper and diesel. While I was at it I put all new seals and o-rings in. Runs great now. Another thing I found was a partially plugged inlet screen on the pump. Might check that first, easy check. If you decide to go into the pump, get a service manual. They are on ebay all the time. PK
Copyright © 1997-2015 Yesterday's Tractor Co.
