TractorLinks.com
Re: Case 310g
AJ.
06-22-2013 02:23:42
Maybe the vandals forced the shift lever out of the selector gate,if you remove the lever you may be able to get them back in line with a large screwdriver,pull up the rubber boot and as I recall there is a snap ring holding the lever in,remove it and the lever should pull up,the boot must be letting the water in when there is water in the oil.
AJ
belsheen
06-22-2013 06:18:57
 Re: Case 310g in reply to AJ., 06-22-2013 02:23:42
I was wondering about the boot being the point of entry; the boot is torn badly and doesn"t hold the shaft very snug. Should be able to engineer something if I can"t find a replacement.
I"ll attempt the fix you mentioned Monday. Thanks for the suggestion.
JC
