Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 350B John Deere crawler
Dieseltech
06-18-2013 04:23:21
Remove the top cover, look inside for any small bits that look like coffee grounds. If there are any pump needs repair. If not, check the metering valve at the rear inside for free movement, it may be sticking, not turning on as it should causing low power. It must move freely, move it back and forth and see if it helps free it up if sticky. Any water in fuel can cause it to stick. If pump has electric shutoff be careful that shutoff arm is in front of black arm boss when replaced. To be safe, use a separate ground jump wire on other cover post and set straight down with key on holding stop arm in. If done wrong engine may run away when started.
Duane having trouble
06-18-2013 18:42:08
 Re: 350B John Deere crawler in reply to Dieseltech, 06-18-2013 04:23:21
Hey dieseltech, I didn't make it out to tinker with the dozer this evening, but I will do my best to get out there tomorrow evening. However, I was wodering what state are you in (for shipping purposes) and approximately how much is average to rebuild one of these pumps?
Dieseltech
06-18-2013 20:16:15
 Re: 350B John Deere crawler in reply to Duane having trouble, 06-18-2013 18:42:08
Located in Indiana. Average range of most I see run 175-250. Seldom over 300 unless cam or other hard parts need replaced.
