Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 350B John Deere crawler
Dieseltech
06-13-2013 11:49:13
To see if the pump needs repair try this, have a screwdriver ready to loosten the 2 timing cover plate screws while engine is slowing down. If speed picks up and will accelerate OK while fuel leaks out past gasket pump needs repair. Weight retainer ring is failing, blocking the return fitting. Don't knock the ball out and think all is well. After awhile retainer pins will break, locking up the head and break the drive shaft too. What I can fix now just became much more cost and work.
Duane in trouble
06-13-2013 19:49:23
 Re: 350B John Deere crawler in reply to Dieseltech, 06-13-2013 11:49:13
I took the section of pipe out that had the ball in it.... Are you saying to put it back in?
Keith Molden
06-14-2013 03:06:31
 Re: 350B John Deere crawler in reply to Duane in trouble, 06-13-2013 19:49:23
Listen to Dieseltech. I DO NOT reccommend removing the ball & driving it that way. I did to get it running long enough to get it back home. This was about 5 years ago and I had it rebuilt. Trust me, Dieseltech will do you a good job at a reasonable price. He has done an injector pump for my Massey 255 and has done several for others on this site. Keith
Dieseltech
06-13-2013 20:17:45
The return fitting you removed is the housing pressure control fitting. Removing it will help engine run better IF it is plugged with small bits of broke retainer ring. I like to test by letting fuel leak out at the timing cover for a quick check. Have even loaded tractors on the trailer this way that would die, then haul them to the shop. It may run OK for awhile with it out, but you will have much more damage later if pump needs repair and doesn't get it.
Duane having trouble
06-17-2013 20:20:11
 Re: 350B John Deere crawler in reply to Dieseltech, 06-13-2013 20:17:45
OK, we have blown the supply and the return line out. We changed the filters again, then we loosened the three screws on top of the pump (the piece that the return line comes out of). the engine just barely reved up as the fuel was leaking out of the box. No change in the way it runs. Any other ideas?
Dieseltech
06-18-2013 04:23:21
 Re: 350B John Deere crawler in reply to Duane having trouble, 06-17-2013 20:20:11
Remove the top cover, look inside for any small bits that look like coffee grounds. If there are any pump needs repair. If not, check the metering valve at the rear inside for free movement, it may be sticking, not turning on as it should causing low power. It must move freely, move it back and forth and see if it helps free it up if sticky. Any water in fuel can cause it to stick. If pump has electric shutoff be careful that shutoff arm is in front of black arm boss when replaced. To be safe, use a separate ground jump wire on other cover post and set straight down with key on holding stop arm in. If done wrong engine may run away when started.
06-18-2013 18:42:08
 Re: 350B John Deere crawler in reply to Dieseltech, 06-18-2013 04:23:21
Hey dieseltech, I didn't make it out to tinker with the dozer this evening, but I will do my best to get out there tomorrow evening. However, I was wodering what state are you in (for shipping purposes) and approximately how much is average to rebuild one of these pumps?
Dieseltech
06-18-2013 20:16:15
 Re: 350B John Deere crawler in reply to Duane having trouble, 06-18-2013 18:42:08
Located in Indiana. Average range of most I see run 175-250. Seldom over 300 unless cam or other hard parts need replaced.
