Aliis HD11 1959 model
AC Tim
I have a leaking rear seal on my HD11. Has anyone done that type of repair, and any suggestions would be most appreciated.
The dozer runs like a Swiss watch otherwise.
The Best
The guys one the construction section of allischalmers____ seem to be doing this frquently and should be able to help.
There are two final drive seals on each side. The outboard seal(between the sprocket nut and the outboard bearing) can be replaced without major disassembly. The inboard seal requires removal of the swingframe and the sprocket.
