JD??? Crawler?? Hood
Chris Van
Anyone ID this hood for me? Came with an Oliver Crawler but there"s no way its an Oliver part unless from pre-"40s.
There"s a small patch of what could be pale Green JD paint on the inside.
That isn't a hood.It is called a sod pan and is
mounted under the engine area of John Deere
crawlers to protect the oilpan.Luck,JimAnderson
@ Bill M.
May I ask what the link is that you used to come up with a PDF form on a John Deere parts breakdown. I use JD"s website for parts, but it leaves a lot to be desired. That picture you have posted is much better.
Thank-You..... Michael
