HUSKY
hi all
i have a a.c.hd4 dozer worked great last fall however now i cannot et it to move ????? does anyone have any ideas ??????? thank you for the help
dave m.
Youre tractor is too new for someone like me to know much about. Perhaps if you describe the problem a little better you will get some answers. There are guys who read this that are real pros. Is is a powershift type transmission and won"t move? Or is it that the engine won"t start? The better you can describe the problem the better. I will say that I don"t think they made that model that long. My book shows 1683 built in 1966. It may be similar to the earlier H3 series.
it is the transmission that will not allow it to move engine starts fine just will not move after sitting the winter
Do you read your reply"s.If your oil level is up & the color red( atf) remove the 1/8" plug on back of f&r control valve install a 200 lb .gauge you need at least 90-100 psi to lock clutches.HAVE YOU CHECKED THE FILTER!!!
