Ford Skidsteer CL30 or CL40
Anonymous-0
Does anyone know where a guy can find parts for a Ford Skidsteer CL30 or CL40 and what is the difference in the two. I need some parts for the 40 model
The 40 is bigger and probably the most common one. I think they were made by Erickson(sp). What parts do you need? Those machines were made in the 70's.
If he needs axles for bad seal areas, they can be taken out, rewelded and turned ona lathe. We did ours on our 722 bobcat. Local machine shop did a good job,no leaks and new seals worked
LOU
I need the hydraulic cylinder that tilts the blade, the one that runs verticle in the front. Also could use a carb to rebuilt,
Anyone know how to contact Casekid (Jim) that responded about he has parts for these skidsteers, I would like to talk with him.
