TractorLinks.com
Re: TD_24
Dennis K (WA)
05-23-2013 12:20:51
All of the TD24's had gear drive transmissions but some had converters with a master clutch and some just a master clutch.
The transmisssions between the two were not the same however. I believe the converter machines had less gears than the ones without.
You need to determine if it has a torque converter or not. It may have something to do with it not moving.
good luck
Dennis
David Bricker
05-23-2013 14:25:23
 Re: TD_24 in reply to Dennis K (WA), 05-23-2013 12:20:51
I was able to get the dozer to move this afternoon. However, when the dozer is under load, such as going up a hill, it stops. I am thinking that the clutch is slipping and needs to be adjusted. I have the manual and will follow this information. Thanks,
David
