Yesterday's Tractor Co.
Shop Now View Cart
Re: Just when you think you got it licked...
LOU from Wi.
05-21-2013 10:57:55
Stick weld. The letters are to close together so my fingers picked out the c or N. Didn't realize it until it was printed . lol. Now as far as J de is concerned at least I had the brilliance of mind to talk with him and take his suggestions rather then sitting at the computer gripeing about the numerous failures of your badly needed maintenance or none at all when you describe your worn out crawler that seems like it never gets any preventative maintenance but just WELL USED over and over. remember , a well maintained unit will last and be at the ready when call upon to perform. I really think you should take your own advice and scrap the one you are trying to patch up . Seems like yours is becoming a MONEY PIT that you preach. LOU
Stick welding
05-21-2013 18:01:05
 Re: Just when you think you got it licked... in reply to LOU from Wi., 05-21-2013 10:57:55
Lou, your finger would have to be 2" wide! Do you think before you post? In your attempt to try and stir the pot with me you made several huge blunders. The biggest is you completely dissed JDE and there is NOTHING you can say that will change that, NOTHING! What I'm reading above is that you didn't want to list all the problems your worn out machine had on this forum. Yes, your machine was worn out and abused.
My machine gets used and sometimes in less than ideal conditions. I do regular maintenance but I don't have a crystal ball to know when something out of the ordinary will go wrong. Put 1500 or 2000 hours on your little Oliver and it will need some repairs. A well parked machine will last too. Hope you put Stabil in the gas tank.
LOU from Wi.
05-21-2013 21:15:35
 Re: Just when you think you got it licked... in reply to Stick welding, 05-21-2013 18:01:05
Welllllllllll ,I type at the speed of light.Sometimes typing becomes a complete blur when addressing ignorant, know it all people. HINT HINT HINT . Now keeping with my train of thought, Just how do you figure I dissed Jde? I'm not a farmer and even though we have a great I.H 706 , I haven't dissed any ground.I am indebted to Jde for all the advice and information he gave us. I keep thinking of a NOT SO KNOWLEDGEABLE like you who wanted me to cut 2" off one side of the new track plates. Remember that error you suggested??? All any one has to do to see that blunder is to go search the archives.Seems like to me your maintenance is most inadequate on your wreck. Bet you think that putting fuel in the tank and water in the radiator is maintenance. lol. I think you missed all our posts on our dozer, everything we did was posted with pictures,or are you forgetting that to your benefit?Again CHECK THE ARCHIVES!!!!!!!!! You're the one who thinks you are so knowledgeable on everything from soup to nuts pertaining to most every subject on this forum,why ask questions to which you already (supposedly)have the answer to? Sounds like you would be money ahead to scrap out your old worn out dozer, and hire a professional to do the work.Another one of your suggestions to us. See archives.
We aren't the ones on here asking about our dozer problems,one after the other, see we do preventative maintenance on ours,like the gas tank and engine oil in the cyl to keep it from sticking every year,unlike you,who seem to forget about any maintenance at the end of the year,and only add stabil to yours.Remember a good mechanic never breaks more parts than is trying to put on the machine.So how much did that $15.00 bolt cost you so far???
Stick welding
05-21-2013 22:15:59
 Re: Just when you think you got it licked... in reply to LOU from Wi., 05-21-2013 21:15:35
"Stinkweld,If you had one like this you would have had the work done already and wouldn't have to consult master mechanics lol."
Definition: "1. dissing someone is showing disrespect to them"
Yah Lou, check the archives! If that's not dissing someone I don't know what is! You were so quick with your sharp wit, you insulting the one person who without his knowledge, you're little toy would still be in pieces! Putting oil in the cylinders? That's not preventive maintenance, that's preventive lack of use. It won't break if it never gets used. You should put it on a trailer already and call it Elizabeth the 3rd! LoL
I thought the whole purpose of this forum was to help each other out? I actually do appreciate the help I've gotten over the years. You, apparently, not so much. HMMM????
LOU from Wi.
05-21-2013 22:30:58
 Re: Just when you think you got it licked... in reply to Stick welding, 05-21-2013 22:15:59
Well you never said what archive I dissed J de on. Cant find it??? Never happened .!!!!!About not using the O.C? Here is another picture of it sitting in the garage as a Beauty queen. What a maroonnnnnnn as bugs use to say. still waiting for your Archive number where you stated I Dissed Now you have to prove it!!!
Stick welding
05-21-2013 22:52:15
 Re: Just when you think you got it licked... in reply to LOU from Wi., 05-21-2013 22:30:58
I put the quote from your first reply to this thread where you dissed JDE. How could you miss that? You used your machine for a whole 5 minutes and 29 seconds, wow! Well, if you take the time off for changing direction, lifting the bucket, it works out to about 4 minutes. LoL
You don't actually call that working the machine do you? Good thing you have soft ground. If you tried that in packed clay would be a good way to bend your bucket cylinders and/or your bucket. If you don't believe me ask anyone else who runs loaders. It even warns against it most manuals and that's without a 2' extension on the front of the bucket. You better leave it in the garage if you run it like that. New cylinders aren't cheap! Unbelievable!!!
LOU from Wi.
05-27-2013 19:42:30
 Re: Just when you think you got it licked... in reply to Stick welding, 05-21-2013 22:52:15
Well SICK WELD, Show me where I* Used Jds name in my post to you!!Never happened,As for using the tree spade, it is not a problem as using a bale spear on front end loaders transporting 1500# bales of hay, over rough bumpy fields. Hyd cylinders are new on our dozer when we bought it. See it's what we know about our dozer that you don't know about yours is hurting your credibility.Since I have run more earth moving equip than you, I know of what I speak. It's called experience, not like you,give yourself another 40 years, you "might" learn something on dozers and crawlers. Just another tidbit of info for you, different ground composition calls for different techniques, IE what works on one type,won't work on another type of ground.You just have to be smart enough to know the difference,like I said, "maybe" for you 40 more years.Since you like manuals, Have you read yours lately? I'm sure they mention things like filter changes and checking the screen on the pump.Above all covering the machine when not in use.The biggest one I'm sure of, it mentions taking it to a "professional mechanic" for repairs,if you don't know what you are doing. Just think it would have saved you all the time and money replacing that $15.00 bolt.
Did you notice our machine kept running and still is after we done all the things we needed done for earthmoving? We are going to use the spade to dig a ditch to the new shed for a power line, saves shoveling.If you wish we can video it for you so you can see how a dozer is supposed to work and run.Might even put some audio explaining to you why we are doing what we are doing and why,plus a little background music I'll write and perform,just for you.
